abs inop
does anyone know what would make the abs inop light go on? it doesnt come on all the time once in awhile, i did have 2 bigger tires on the back but i have the same size now on all 4. if i turn the car off and start it again the light goes off.also does anyone know how to fix it? thanks for your help
May be a bad sensor. Bad news is, the ABS sensor is integrated with the wheel hub.
I wound up replacing both my fronts (one bad bearing, one bad ABS sensor).
You might get a reading from a scanner to say which one.
Oh, and if it matters, the ABS system resets every time you turn on the car - so the light will go out at start-up, but come back on in a few dozen yards of driving. It may also cause a braking issue if you start off going downhill.
have your alternator checked. When i had my camaro, i installed a new head unit, my abs light came on guages acted all funny and finally it wouldnt start, so i brought it to be tested and sure enough it had gone south and wasnt charging the battery.
Get your ABS system scanned to find out where in the flow-tree the problem lies. In my case, my '95 had a bad ABS Motor Pack an easy replacement to do yourself, but I paid to have the ABS diagnosed to zero in on the problem.
ORIGINAL: Spartan66
So explain why when my alternator started todie after i installed my headunit the ABS light came on and then when i got a new one it turned off?
The bestway to find the problem is to take it to a dealer or shop and have them hook it up to a tech 2and see what the problem is.
