Cooling system issues
Old Jul 14, 2008 | 06:46 PM
superhotchevy's Avatar
Default Cooling system issues
My fans work great, I just replaced the thermostat (installed correctly) the water pump is good, it's full of coolant and for some reason it keeps trying to overheat. i have no leaks either but it keeps overheating. I'm stumped... i need some real advice.
Old Jul 15, 2008 | 07:03 AM
aightball87's Avatar
Default RE: Cooling system issues
check the coolant sensor on the left bank head. (right side if looking at the motor) it is just below the exhaust. if it is reading wrrong it would definately be the problem.
Old Jul 16, 2008 | 12:16 PM
EnFuegoZ28's Avatar
Did you bleed the system??
Old Jul 16, 2008 | 12:41 PM
What year and engine do you have? You first need to determine whether your gauge is telling the truth or not. Has your water pump been replaced shortly before the overheating started, by chance? Older v-belt set-ups used a conventional rotation water pump, serpentine uses reverse rotation. If there was a mix up, it will cause overheating.
Pig Hunter
Jan 31, 2012 03:09 PM
fergie24
Apr 14, 2010 06:52 AM
clyon
Jun 8, 2009 11:46 PM
tdeckaa90
Feb 28, 2009 07:01 PM
bconz350
Jan 4, 2007 10:30 AM
