air vents
Old Jul 14, 2008 | 06:50 PM
phillipiruss's Avatar
Default air vents
i have a 99 3.8 and my upper vents dont work. i have air at the floor board. i changed the switch and the vacuum line leading out to the hood but dont know where to look next.
Old Jul 14, 2008 | 09:54 PM
Default RE: air vents
The air is directed to different places my moving the air doors inside the HVAC plenum. The motion of the air doors is controlled by vacuum powered actuators/motors.
[IMG]local://upfiles/1197/D20A0E203D0A4DE2A712D7D7CC7A59DA.jpg[/IMG]
Old Jul 17, 2008 | 10:21 PM
t9ojetpilot's Avatar
[&:] the doors are controlled by vacuum and more than once ive found the vacuum supply lines or the tee/one way valve at the firewall to have broken. id check this stuff first kurt
Old Jul 18, 2008 | 02:08 AM
MadMikeZ28's Avatar
Do you have defrost? Ifyes thenyou couldsuspect no vacuum. Defrost is a default so you will always have if for safety. If no defrost then maybe some thing could have also fallen in through the vents and jambed a door.
vbachtold
Sep 9, 2012 12:04 PM
chris.langlais
Oct 13, 2011 01:31 PM
iLL95
Sep 16, 2011 08:50 AM
imawesome
Apr 4, 2006 11:57 PM
