Floor vents and defrost work but not the panel vents? HELP!
Old Oct 5, 2011 | 01:36 PM
chris.langlais's Avatar
Default Floor vents and defrost work but not the panel vents? HELP!
I have a 1994 3.4 V6 and Im having problems trying to fix the vents. I've read a couple thing off the internet but with no luck. I dont really know a lot about cars but Im working on it! What could possibly be wrong? And what would be the easiest way to fix them?
Old Oct 5, 2011 | 01:47 PM
JGuy07's Avatar
4th Gen LT1 F-body Tech Articles
That may be what you need to look at.
Old Oct 5, 2011 | 03:06 PM
iLL95's Avatar
I Like to Party
Super Member
Replace the vacuum check valve. Over time they crack causing a vacuum leak. Does your car also kind of idle rough? it causes that also.When the vacuum system has a leak it tends to draw the air into your floor and windshield vents. It's a small black canister located up and to the left of your alternator. it has 3 lines connected to it. unplug all the lines(Carefully) and see if it's cracked or damaged. If so replace it.Here is the link to the check valve I bought.
93-02 Camaro Firebird Heat/AC Vacuum Check Valve NEW GM | eBay
Old Oct 6, 2011 | 09:38 AM
thanks guys I will make a trip to the parts store sometime today and will get back to you and let you know if that worked! thanks again!
Old Oct 6, 2011 | 09:52 AM
can you switch from floor to defrost or does it blow from both and not change.
Old Oct 6, 2011 | 09:58 AM
iLL95's Avatar
I Like to Party
Super Member
If it's what im dealing with then he cant switch, just blows from both
Old Oct 6, 2011 | 10:20 AM
iLL95's Avatar
I Like to Party
Super Member
Just put the valve on and my A/C blows perfectly and switches from dash to floor, etc
Old Oct 6, 2011 | 10:28 AM
right i was trying to figure out if the vacuum leak is in the switch valve or the vacuum source like hose or check valve.
Old Oct 6, 2011 | 12:08 PM
I replaced the vacuum check valve but that didn't work, the old one did have a small crack in it so maybe I have another leak somewhere? No I can't switch from floor to defrost, it just blows out both of them.
Old Oct 6, 2011 | 12:39 PM
iLL95's Avatar
I Like to Party
Super Member
Thats odd mine works just fine, might be a dumb question but did you get the triple line valve? When I went to autozone they sold me the double line valve so i returned and ordered the triple
