Floor vents and defrost work but not the panel vents? HELP!
Old 10-06-2011, 01:05 PM
chris.langlais's Avatar
yes the valve I got has three lines into it, Im in the process of taking apart my dash to see if maybe something is blocking one of the vent doors but other then that I have no idea what could be wrong
Old 10-06-2011, 01:25 PM
JGuy07's Avatar
Did you check out the link I posted?
Old 10-06-2011, 01:37 PM
Old 10-06-2011, 01:45 PM
Yes I checked the link and it helped a lot, I don't really have the tools or time to trace each vacuum line and see if they are good or not, Im thinkink of calling the local chevy dealer and see if they can look at it...
Old 10-06-2011, 02:00 PM
When I went to O'Reillys to get a new check valve the guy looked at me like I was retarded and didn't know what I was talking about, he tried to sell me like three different valves but I ended up bringing him to my car and showing him what I needed, he said that they didn't have those, I went to the chevy dealer and asked them, the guy sold me one but it looks alittle different then the one I took out of the car, I just searched the O'Reillys website and they have the exact one that I took out, could that be the problem?
Old 10-06-2011, 03:37 PM
This may not matter but when the car is off I can move all three ***** with ease but if the car is running, I can move the fan speed and mode selector freely but the temp control has some resistance when I turn it to the left. Just spitting some ideas out...
Old 10-06-2011, 03:46 PM
JGuy07's Avatar
Usually the problem is just a vacuum leak somewhere. Unless you've been pulling on the lines which would lead to other problems like pulling them out or tearing them obviously. Did you check with a parts store on whether they loan the gauge out? I'm not sure if they do but heck they loan just about any other tool you need. But yes, typically it is that valve that leaks it dries and cracks.
Old 10-06-2011, 03:57 PM
temp control is a cable that goes to a door. should not make any difference if car is on or running.
Old 10-06-2011, 05:39 PM
1augapfel's Avatar
It's a Federal Motor Vehicle Safety Standard (FMVSS) that a climate control system failure must cause max heat and defrost. This is so the windwhield will be clear for safe driving.
If the temp isn't vacuum or computer controlled then only air discharge location is affected (and it sounds like this is the case for your car).
Digging around behind the dash and taking the car to a dealer <gasp> will cause nothing but trouble. Find out why vacuum isn't getting to the dash control panel.
  #20
Old 10-06-2011, 06:27 PM
Ive been pretty careful when handleing the vacuum lines but anything is possible. I will ask around for a gauge to test the lines, I hope I figure this out soon! Its such a pain!
Quick Reply: Floor vents and defrost work but not the panel vents? HELP!
