305 to 350 starter problem
Old 10-23-2007 | 09:17 AM
cjsuret's Avatar
Default RE: 305 to 350 starter problem
Has anyone ever matched a 350 and a t5?
Old 10-23-2007 | 12:40 PM
MadMikeZ28's Avatar
ORIGINAL: cjsuret
Mad Mike, I am only replacing the engine.The car originally had the 5 speed. The bell housing on the five speed didn't have enough clearance for a 168 tooth flywheel. It was originally 153. ANd yes I had to order it cuz there arent many made with 153 tooth, and large crank holes.
And your 305 starter will not bolt to the 350 block now with the stagered holes??? Did the 305 not have the stagered patern on the starter?
Yes GM has
Old 10-23-2007 | 01:30 PM
TommyB's Avatar
My '87 IROC has a 350, with the T5. Granted...the T5 just died, but the point is, it works in it..
Old 10-23-2007 | 04:08 PM
cjsuret's Avatar
so do you have the 153 tooth fly wheel, and the inline starter mounting bolt holes? Wanna sell your motor ? LOL
Old 10-30-2007 | 08:43 AM
cjsuret's Avatar
OK Guys, I drilled it out, and it is working great. The starter that is, I an not getting ignition, but that is another post. SO thanks for all your help, and advice, and My guy at Oreilly's found a starter for this application if any of you ever run into this again.
numskull223
08-30-2011 06:46 PM
RandyZ28
08-24-2009 04:44 PM
cjsuret
10-22-2007 01:47 PM
Piero
07-19-2007 06:13 AM
chaeridley
02-19-2006 03:33 AM
Quick Reply: 305 to 350 starter problem
