Starter problem.
Old Feb 18, 2006 | 04:29 AM
chaeridley's Avatar
Default Starter problem.
I have the craziest problem with my car. After cruising it around a bit, maybe an hour, I turn it off. I hop back in a few mins later and the car acts like the battery is unplugged. I turn the key and absolutely nothing happens. No click not a thing. I usually have to wait 10 - 15 mins and try again and it works. I'm guessing it's some weird electrical problem. Anyone have any ideas about it?
Old Feb 18, 2006 | 11:33 AM
gmpartsguy's Avatar
Default RE: Starter problem.
Next time it happens, try banging on the starter with a hammer or something. If it starts after you hit it a couple of times, you have a bad starter.
Old Feb 18, 2006 | 08:15 PM
v8chvyguy's Avatar
I'm with GM, the heat make the starter sieze up. After it cools alittle it starts. I have the same issue sometimes w/ my 79 Z.
Old Feb 18, 2006 | 11:40 PM
creep's Avatar
ya know, i had a similar problem with an old mustang i had. only the culprit wasnt the starter, it was a ground wire that would melt to the header when it was hot, then after it cooled it wud start again.. just my 2 cents of another problem that may be the case.
Old Feb 19, 2006 | 03:33 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
had that same problem. i heat wrapped the starter after taking it out and changing it the 5th time. not fun
numskull223
Aug 30, 2011 06:46 PM
RandyZ28
Aug 24, 2009 04:44 PM
cjsuret
Oct 30, 2007 08:43 AM
cjsuret
Oct 22, 2007 01:47 PM
Piero
Jul 19, 2007 06:13 AM
