1968 hei upgrade problems
Old Apr 11, 2007 | 03:29 PM
a356708's Avatar
Default 1968 hei upgrade problems
I am upgrading to hei from points ,the distributor is off a 1984 chevy g20 van .It is going on a 327 .i replaced cap rotor plugs new 7prong ignition module i get no spark .there are other wires that used to go to the vans ecm .Could it be i need a4 prong ignition module for this distributor to work . I dont have a tach yet so i have not plugged in the wire on the distributor.But i think the body if the would ground it .Right? need some help .
Old Apr 11, 2007 | 11:16 PM
RatMotor's Avatar
Default RE: 1968 hei upgrade problems
Yep....
You need a 4 pin module. The 7 pin modules are for computer controlled engines.
RM
Old Apr 11, 2007 | 11:41 PM
MadMikeZ28's Avatar
Do you plan on using a distributer without a vacuum advance? You can get a pre79 dist with it.
Old Apr 14, 2007 | 01:33 AM
t9ojetpilot's Avatar
[X(]if youre not sure of what youre doing(4,7 pin etc) i would suggest you purchase a complete hei with vacuum advance as i believe complete aftermarket assemblies are getting down around $100 and this unit would be almost literally plug and play for you kurt
gloveside45
Jul 31, 2010 10:32 AM
camarotodd
Feb 28, 2008 08:50 PM
a356708
Apr 11, 2007 06:32 PM
