small block 305 hp boost for under 750$$
Old Sep 6, 2008 | 11:57 PM
c4maro's Avatar
Default small block 305 hp boost for under 750$$
Hey, im 15 and i gotta 87 z28, its got a pretty much stock 305, i just put high performance wires and plugs on it, and high output moduel and rotorcap. I sold my dirtbike for 750$ and now i need some tips to get more hp with hurting my lowerend. so if you couldgive mesome tipsto do to my 305 foraround 700$ that would be GREAT.
thanks, Cole M
Old Sep 14, 2008 | 09:16 AM
captblue1's Avatar
Default RE: small block 305 hp boost for under 750$$
my nephew is in the same position as you are. he has an 88 formula. your z28 probally has 2.73 gears in the rear end if it is an automatic. i would use the money to put 3.55 or 3.73's in. it will give you the biggest seat of the pants increase. after that, i would put an exhaust. putting a 350 in place of the 305 will be a cheaper increase for power than trying to get more power out of the 305. You will probally only be able to get the gears for $750, but now you know what you have to save money for.
Here is a good site for 3rd gen specs
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
Bob Jones
Nov 22, 2007 11:49 PM
