Fuel Guage not reading
Old Mar 10, 2011 | 09:24 PM
danny's Avatar
Default Fuel Guage not reading
There was a new fuel tank installed prior to my purchase and not sure where to start looking to trying and figure out why the fuel guage is not reading.
Old Mar 11, 2011 | 12:19 PM
It would help a lot if you told us what year your car is. I'm guessing somewhere between 1967-2002. Am I close?
Old Mar 11, 2011 | 12:41 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
just tape a peice of paper over the gauge that shows full... youll be fine
Old Mar 11, 2011 | 02:57 PM
Just curious, is your tank half empty or half full?
Old Mar 11, 2011 | 03:11 PM
danny's Avatar
Yes lol 67. I thought the same and filled it up and it was full
Old Mar 11, 2011 | 03:28 PM
Are you saying it reads full all the time?
Does the needle move back down when the key is off?
Old Mar 11, 2011 | 09:21 PM
danny's Avatar
No it shows empty all the time and it does not move when started or bounce while moving down the road.
Old Mar 11, 2011 | 10:07 PM
You need to find out if there is a short in the wiring or not. With the key on, pull the gauge wire off the sending unit, should be a tan one (not the black wire on the ground tab). If the gas gauge pegs to full, it's the sending unit that's the problem. If nothing happens, that tan wire could be grounded out somewhere. Btw, touching that tan wire to ground will/should peg the needle to empty, and with it disconnected should peg it to full (I know, sounds opposite of what you would think, but that's how it works). If still nothing, check to make sure you have power going to the other side at the back of the gauge (or you could check for power there first if you think it's easier).
tyler_caz18
Feb 1, 2014 09:36 AM
richard.nelson100
Nov 15, 2011 11:30 AM
osduck5
Aug 6, 2011 11:21 PM
L8RDUDE
Jan 3, 2010 10:51 PM
camarofreak1990
Jul 5, 2008 10:27 PM
