fuel guage?
Old Jul 3, 2008 | 08:27 AM
camarofreak1990's Avatar
Default fuel guage?
on my 2000 camaro my fuel guage fluxuates like crazy! every time i take a hard right turn my fuel needle falls really far! when i take left turns it goes up. do anyone know how to fix this?
Old Jul 3, 2008 | 09:58 AM
meteoralp45's Avatar
Default RE: fuel guage?
all f-bodys and most GMs do this, not much you can really do about it
Old Jul 3, 2008 | 08:11 PM
Chappie99's Avatar
there is plenty you can do. You can replace the sending unit. Its expensive just for the part, you'llbe looking between 3-4 hundred just for the part.
Old Jul 3, 2008 | 09:25 PM
BeraniHull's Avatar
My sending unit isn't all that bright either...two weeks ago I put 3 gallons in (the gauge was at E) and when I started the car up, it said 1/2 tank. Yesterday I gave it 4 gallons (from E) and it said 1/4th of a tank...
Old Jul 3, 2008 | 09:36 PM
so is there somethin you can do to make it more accurate, cause from my understanding all these cars gas gauges flux
Old Jul 3, 2008 | 10:19 PM
Saint_Ali's Avatar
its always going to flux, the only way to get an accurate reading is when the car is stopped on a flat surface, its liquid so it will move around a lot which gives it an inacurate reading
Old Jul 4, 2008 | 05:37 AM
Guest
Guest
Posts: n/a
Ok dont ever let it get that low unless you like changing fuel pumps first of all, and our cars gas tank is rather "V" shaped, so at the bottom a little looks like alot, and vice versa at the top. It wouldnt fluctuate so much if there was enough gas in the tank that it sloshes around that much.
Old Jul 5, 2008 | 10:27 PM
xCx777's Avatar
yea my 96 does it too... after a while you get used to it, and you learn how to judge how much gas is actually in your car even with the gauge going a lil crazy...
tyler_caz18
Feb 1, 2014 09:36 AM
osduck5
Aug 6, 2011 11:21 PM
danny
Mar 11, 2011 10:07 PM
g3mini609
Jan 15, 2010 01:53 PM
pimp2303
Sep 27, 2009 01:10 PM
