crankshaft ???
Old Aug 4, 2006 | 06:25 PM
benz660r's Avatar
Default crankshaft ???
Hey guys,
Im a still kind of new to the forums but and currently rebuilding a chevy sb and looking to make 400 hp and around equal torque. My question is can i use the cast iron crank or do i need to upgrade it? Also what hp ratings are for each crank from cast iron to forged iron to cast steel and forged steel? To what hp can each crank hold up to?
Old Aug 5, 2006 | 02:30 AM
firebird69racer's Avatar
Default RE: crankshaft ???
all cranks are steel, cast or forged
a cast crank would be fine, unless you plan on using NOS
Old Aug 8, 2006 | 08:21 PM
blackz87's Avatar
ORIGINAL: firebird69racer
Cast Iron
Cast steel
Forged steel
All have different properties. I see that you have never taken Strength of Materials 101.
Old Aug 9, 2006 | 12:12 AM
MadMikeZ28's Avatar
How much do you want to spend? You can get a 4340 steel crank and spend bucks or a 5140 and give up a little strength and cost. Or, just buy yourself an already built motor from summit.
fasttony350
Feb 18, 2012 04:50 PM
reloadx510
Jan 25, 2010 06:49 PM
uestraven
70-81 V8 Tech
Jan 8, 2010 09:13 PM
GR95Camaro
Mar 25, 2006 06:17 PM
97Cam3.8
Jul 10, 2005 01:57 PM
