building engine
Old Mar 27, 2006 | 12:49 AM
383Z28's Avatar
Default building engine
everyone here is talking about there motor i feel left out i have a 84 Z28 5 speed i have been working on motor is being built off of a 87 iroc roller block eagle crank 6in rods cran 509 lift roller cam roller lifters 202 vortec heads air gap intake dont no about carb. yet thinking 750 id like to see 400hp to the wheels engine builder said it should not be a problem????????
Old Mar 27, 2006 | 11:27 AM
JD1969's Avatar
Default RE: building engine
Sounds like a nice setup.
Old Mar 27, 2006 | 08:12 PM
TimmyTheWop89's Avatar
i would suggest a 750cfm carb. a lot of people say a 650 is perfect for a 350, which they are right, if the motor doesnt exceed 380 horsepower. but if you are looking to hit 400 horsepower, a 750 will be much better suited, youll have plenty of breathing room with it.
Old Mar 30, 2006 | 09:15 AM
mike86rs's Avatar
I agree, it sounds like a good set up. Let us know how it runs when you get it done.
Old Apr 5, 2006 | 12:28 AM
shnormo's Avatar
I would also recomend a high performance cam with lifters and rocker girdles. I know you can easily get 400 HP.
Old Apr 5, 2006 | 07:11 PM
i think he does already have a bigger cam in there.
Saundra Hightower
67-69 V8 Tech
Nov 22, 2011 04:48 PM
68muscle
67-69 V8 Tech
Dec 28, 2009 02:27 PM
hurley870
Jul 28, 2007 11:00 PM
1bad96Z28
Jun 21, 2007 10:41 AM
355CAMARORS
Mar 15, 2007 04:25 PM
