re-building an engine
Old Dec 28, 2009 | 01:55 PM
68muscle's Avatar
Default re-building an engine
almost two years ago now i twisted the crank in my 68's 350 engine. we finally got it all torn apart and a new crank put back in it and are working to get it running again. the problem is the crank shaft that came out of it was from a 327 motor. naturally we put the 350 crank back in it. can anyone tell me what kind of performance changes to expect? any help would be great! thanks
Old Dec 28, 2009 | 02:27 PM
Originally Posted by 68muscle
...the problem is the crank shaft that came out of it was from a 327 motor. naturally we put the 350 crank back in it. can anyone tell me what kind of performance changes to expect? any help would be great! thanks
If you had a 327 crank in that engine, you had a 327 engine, not a 350. 327 and 350 has the same 4" bore size. 327 stroke is 3.25" and the 350 is 3.5". If you slap a 350 crank (with .25" more travel than the old crank) to the rest of the existing rotating assembly, the greatest change you're going to experience is the pistons coming to a dead stop as they crash into the heads. To make what you have work, you'll need shorter rods.
Saundra Hightower
67-69 V8 Tech
Nov 22, 2011 04:48 PM
hurley870
Jul 28, 2007 11:00 PM
1bad96Z28
Jun 21, 2007 10:41 AM
355CAMARORS
Mar 15, 2007 04:25 PM
383Z28
Apr 5, 2006 07:11 PM
