350 sb engine ticking
Old May 4, 2011 | 02:23 PM
justinw23453's Avatar
Default 350 sb engine ticking
I recently replaced my head gaskets and put my engine back together. It cranks over and runs and I can drive it. The problem is there is a ticking sound, and it the amount of times it ticks increases when there are more rpms. I think it might have to do with something with the distributor, because I think thats where the sound is coming from but I'm not sure. It also lags a little bit when I hit the gas in realtion to the ticking. If anyone has idea please let me know. THANKS.
Old May 4, 2011 | 02:25 PM
Old May 4, 2011 | 02:27 PM
SpecterGT260's Avatar
Ninja Administrator
Threads merged: it doesnt get you more responses to post in different sections, just divergent ideas. better to keep it all in one place
Old May 4, 2011 | 04:24 PM
Most likely the valve clearance is not properly adjusted, or there is an exhaust leak between the heads and exhaust manifold, or spark jumping to ground, I never seen or heard a distributor making ticking noises.
Old May 5, 2011 | 08:14 AM
Could these problems cause the engine not to run smoothly, it seems to run kind of rough too.
Old May 5, 2011 | 01:33 PM
A spark jumping to ground and maladjusted valves can cause rough running, but a leaky exhaust will have little effect.
Old May 6, 2011 | 08:44 PM
MelloYello's Avatar
almost positive its da valve clearance.. cuz if u think its from the dist, the valve cover is near by so they prolly need adjusted.. if u know to change head gaskets im sure u know how to adjust valve lash
Old May 6, 2011 | 09:28 PM
GLENN M's Avatar
take your cap off and make sure nothing inside has a CLEARANCE ISSUE,THEN RESET ALL YOUR VALVE CLEARANCES,THEN SET TIMING,YOUR PROBLEM WILL BE CURED
Brendon
Jan 14, 2014 03:04 AM
94ZSLP
Nov 9, 2013 07:22 PM
justinw23453
70-81 V8 Tech
May 10, 2011 11:55 PM
z28 unleashed
Jul 2, 2008 11:43 PM
94Camaroman
May 22, 2006 01:24 AM
