350 sb engine ticking! Please help!
Old May 2, 2011 | 09:29 PM
justinw23453's Avatar
Default 350 sb engine ticking! Please help!
I recently replaced my head gaskets, and I put it all back together. Had trouble with timing issues, distrubtor, etc...Replaced the battery, dist cap and rotor, new spark plugs, new spark plug wires, etc. I have it running now but now there is a loud ticking sound whenever the engine is on, ideling, high rpms, etc. Does anyone have any idea of what it could be?
Old May 2, 2011 | 10:14 PM
Depending on where the ticking is coming from, I'd say either your valve lash isn't set correctly, or you have an exhaust leak.
Old May 10, 2011 | 06:50 PM
gearhead79rs's Avatar
if you just put everything back together and have broken in the engine/ warmed it up and got it hot, you should go back thru and readjust your valves. i just got done replacing everything from the head gaskets up and i had a similar issue. there is even some videos on youtube on how to adjust your valves while your engine is running to get them set perfectly, good luck.
Old May 10, 2011 | 11:55 PM
Or a plug wire shorting to ground.
Brendon
Jan 14, 2014 03:04 AM
94ZSLP
Nov 9, 2013 07:22 PM
justinw23453
May 6, 2011 09:28 PM
z28 unleashed
Jul 2, 2008 11:43 PM
94Camaroman
May 22, 2006 01:24 AM
