Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
No Fuel
Old Apr 10, 2012 | 01:05 AM
  #31
Pig Hunter's Avatar
Ya, you can by-pass the key-code part pretty easy. But, I need to get the 5 volt signal to the PCM. I'm gonna work on a few things in the morning before I fly back to New Orleans. I knew this rebuild was going to smooth....................
Old Apr 19, 2012 | 07:39 AM
  #32
Pig Hunter's Avatar
Found several different solutions over the last few days that could work. So, I'm trying the shotgun effect; Found a guy to program the VATS out of the PCM for a reasonable price and sent him the original PCM yesterday, should have it back within a week, bought a bypass module that bypasses the fuel cut off and sends the 50Hz fuel enable signal independently and sent my spare PCM out to have it flashed. Should all be there when I get home on the 26th. Gonna try them in order listed, so far I'm out $100. If either one works it's a bargain. Will post again after I try each.
Old May 23, 2012 | 07:19 AM
  #33
Pig Hunter's Avatar
Just call me Homer!! After sending PCM out and having the VATS programmed out, still didn't work! But, I must have missed the most important thing in my original troubleshooting. All fuses and power at the fuse blocks were good, however there was no power at the PCM. DOH!!! Jumpered the orange (always hot) wire to the battery and the car started right up and runs unbelievably good. Unfortunately I wasted a lot of my time and yours chasing down gremlins that weren't really hiding. Thanks for all the help guys, gals, just remember "When all else fails, it's usually the simplest thing"
Kendagenius
Feb 5, 2017 12:23 PM
mrfreez
Jan 21, 2011 11:58 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
