Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
gas tank???
Old Sep 10, 2007 | 07:04 PM
bigmike1112's Avatar
Default gas tank???
i have a 91 camaro with the fuel pump in the gas tank. when did they start doing that. i need a gas tank without the pump. ty mike
Old Sep 10, 2007 | 08:26 PM
blackz87's Avatar
Default RE: gas tank???
Since day one with 3rd gen cars....
Old Sep 12, 2007 | 10:42 AM
1985RS's Avatar
three options.
1. drop the tank, pull the pump out and install an inline or mechanical pump
2. get a custom built fuel tank
3. dissconnect the supply fuel line (by the fuel filter is the easiest), blow compressed air back towards the tank until you hear it gurgling, have a pan ready and let off the air. what that does is blow out a seal inside the pump that only allows fuel to be pushed through it. with that seal destroyed, fuel can be pulled through the pump as if it was not there
EagleRex
Jul 31, 2010 11:50 AM
oem6pak
Jul 30, 2010 11:14 PM
kats69
Jul 2, 2009 11:34 PM
swp5767
Jan 11, 2009 08:26 PM
fatty2828
67-69 V8 Tech
Oct 17, 2008 08:15 PM
