LT1/LT4 Tech 1993-1997
gas tank
Old Jul 29, 2010 | 01:16 PM
EagleRex's Avatar
Default gas tank
i need to get to the fuel pump, do i have to drop the gas tank, is so, how do i get the gas tank down? in a real crisis here.
Old Jul 29, 2010 | 09:47 PM
you have a couple couises, drop the tank which involves dropping the rearend and exhaust and is the way gm calls for it to be done.
or you can cut a hole, also known as the hatch mod.
Old Jul 30, 2010 | 11:07 AM
EagleRex's Avatar
isnt that risky tho,
Old Jul 30, 2010 | 11:31 AM
well yah it could be if your doing it with a sawzall. i have not done it yet but people have used heavy duty tin snips, some use air powered cutter.
Old Jul 30, 2010 | 03:23 PM
dopez28's Avatar
i took the tank out when i did mine, just couldnt bring myself to cutting a hole. its a little bit of work. but could all probly be done in a day.
Old Jul 30, 2010 | 03:43 PM
MelloYello's Avatar
what do u do aboot the hole? weld it up or cover it so you can access it later? i guess method two would only be for those who dont mind the sent of gas in there interior.....
Old Jul 30, 2010 | 04:43 PM
lol yah you make a lid for it, seal with sealer and screw it down.
Old Jul 30, 2010 | 05:13 PM
This was on my 91, but the concept is still the same. After getting it that far (with an air cut-off tool), I decided I didn't want to cut the lines and flare the high pressure supply line to connect it back together the right and safe way. So, I ended up dropping the tank anyway. I made a cover out of a new piece of sheet metal, then siliconed/screwed it down.
Old Jul 31, 2010 | 01:08 AM
EagleRex's Avatar
all went well, that little cut out work great. little cut up tho.
Old Jul 31, 2010 | 09:18 AM
pictures?
