gas tank
i need to get to the fuel pump, do i have to drop the gas tank, is so, how do i get the gas tank down? in a real crisis here.
1 Attachment(s)
you have a couple couises, drop the tank which involves dropping the rearend and exhaust and is the way gm calls for it to be done.
or you can cut a hole, also known as the hatch mod. Attachment 33277 |
isnt that risky tho,
well yah it could be if your doing it with a sawzall. i have not done it yet but people have used heavy duty tin snips, some use air powered cutter.
i took the tank out when i did mine, just couldnt bring myself to cutting a hole. its a little bit of work. but could all probly be done in a day.
what do u do aboot the hole? weld it up or cover it so you can access it later? i guess method two would only be for those who dont mind the sent of gas in there interior.....
lol yah you make a lid for it, seal with sealer and screw it down.
2 Attachment(s)
This was on my 91, but the concept is still the same. After getting it that far (with an air cut-off tool), I decided I didn't want to cut the lines and flare the high pressure supply line to connect it back together the right and safe way. So, I ended up dropping the tank anyway. I made a cover out of a new piece of sheet metal, then siliconed/screwed it down.
Attachment 33265 Attachment 33266 |
all went well, that little cut out work great. little cut up tho.
pictures?
