Cant get gas into the tank
Old Aug 31, 2008 | 07:16 AM
swp5767's Avatar
Default Cant get gas into the tank
This is my first post on the camaro forum.
I bought this 99 camaro a couple of weeks ago, and the issue I have is getting gas into the tank. There is some kind of venting issue and thats what im trying to figure out. The tank is not venting properly when you put gas in the car. The fill tube is very small and the typical fuel nozzle will fill it completly. With that, there is no where for the fumes/vapor to escape.
I have no SES light and the car runs fine. With talking with other people, one of the main suggestions is the charcoal canister or the purge solonoid. Both of which look like a real pain to get at. I was under the car yesterday looking at it.
Hope you guys can help.
Thanks
Old Sep 3, 2008 | 06:52 AM
swp5767's Avatar
Default RE: Cant get gas into the tank
Bump.
Still looking for some help on this one.
Thanks.
Old Sep 3, 2008 | 11:42 AM
LT1RUNNER's Avatar
Does it have a vent hole of some type on the fill nozzle? That's a first I've heard of that.
Old Sep 3, 2008 | 03:26 PM
swp5767's Avatar
I searched the LS1tech site too and there was info there, but no real solutions.
People suggested turning the nozzle upsidedown. That doesnt work.
The problem here is the fill pipe is very small. Its about the size of most gas station nozzles. When fuel is going in, the air cant get out.
Old Sep 3, 2008 | 03:45 PM
SpecterGT260's Avatar
Ninja Administrator
i have never heard of this problem..... sometimes the fuel will back up, it depends on the speed of the pump. try just pumping it a little slower. most nozzles have several teeth on the lock, pick a slower one and see.
Old Sep 3, 2008 | 04:11 PM
swp5767's Avatar
Trust me when I tell you, the pumps cant pump slow enough to keep the gas from spilling back out.
If I use a gas can, I can pour it slow enough to keep it from spilling.
Its a venting issue, just dont know where.
Old Sep 3, 2008 | 05:11 PM
LT1RUNNER's Avatar
Then check the pipe that runs to the gas tank. Possible that that there may be anbent or smashed pipe that may be resricting the flow of fuel which may be causing the back flow and causeing the pump to turn off?!??!?
Old Sep 3, 2008 | 05:12 PM
mrEmolitov's Avatar
IDK if this is bad for yor car but try leaving the car on while you pump fuel. just a suggestion.
Old Sep 3, 2008 | 05:27 PM
swp5767's Avatar
MrE, I may to give that a try. Good suggestion.
As far as the pipe going in, its dead straight with no defect. Im able to see the whole line.
Old Sep 4, 2008 | 04:55 PM
swp5767's Avatar
Here the latest.
I ran a very long coat hanger in the filler neck and hit nothing.
I was also able to test the purge solonoid and that appears to be working fine. I took off the vacuum line with the car running. I could here a vacuum leak. I took of the power connection and could hear/feel the difference between being on or off.
