speaker distortion
Old Mar 22, 2008 | 08:57 PM
jj71787's Avatar
Default speaker distortion
ever since i bought new speakers for the front doors the speakers have been having distortion in them
i sent them back and got a new pair and still have the problem
i thought it was the headunit so thats being repaired i put the stock stereo back in today and noticed the speakers are still doing it
its mostly the right side speakers
but if i turn the balance to the the left the left side does it too[/align]
Old Mar 26, 2008 | 04:04 PM
sicked_wick's Avatar
Default RE: speaker distortion
did you wire the speakers yourself? Are they aftermarket or stock?
Old Mar 26, 2008 | 05:36 PM
Camaro_Boi69's Avatar
is it when u turned up reall high?
or ur deck settings are doing it most likely.
Old Mar 27, 2008 | 06:06 PM
jj71787's Avatar
It does it around 35 I did the wiring myself crutchfield.com said I need an amp to power it
Old Mar 28, 2008 | 01:44 PM
ninetysixyenko's Avatar
more than likely the speakers arent getting enough power, but they still shouldnt distort anymore than stock ones. do you have them wired right?
Old Mar 29, 2008 | 06:45 AM
jj71787's Avatar
Yea there wired right the guys on fullthrottlev6 said aftermarkets usually do that because they need an amp
Old Mar 29, 2008 | 10:29 AM
mine never did that in either car i've owned. and any vehicle i'ce installed them in.. if anything, you're head unit is underpowering them(which it is) which would not cause distortion, unless the treble bass, etc is cranked to the max.
but a amp will make them sound 100x better.
Old Mar 29, 2008 | 03:57 PM
jj71787's Avatar
My radio is bein repaired right now so I put the stock in and the speakers r messed up with that radio too
Old Mar 29, 2008 | 10:32 PM
that leads me to beleave there's something wrong with your speakers. post a video?
Old Mar 29, 2008 | 11:53 PM
jj71787's Avatar
i dont have a video of it but i exhanged the speakers and it still does it crutchfeild.com says they need an amp because the factory amp doesnt give off enough power
UFGatorFan
Sep 29, 2014 09:14 AM
Mtm5237
Dec 30, 2010 12:39 PM
nickplee
Jul 21, 2010 05:39 PM
mamoth713
LS Series Tech
12
Jun 29, 2009 12:15 PM
BIG.D
Aug 28, 2008 08:58 PM
