Will not start:/ Help!
I have a 96, 3.8 v6 engine on my camaro. The car ran sporatically (did not accelerate consistantly while constant pressure on gas peddle, would pull forward while foot on break at a complete stop, check gages light on) for awhile and turned itself off 3 times because of overheating.
Things I tried:
I changed the starter because it would not crank. After that it did start but not easily and never twice within 20 minutes.
Recently changed the thermostat, water pump, serpentine belt and pcv valve but car will not start. It cranks but sounds like it is not getting gas or somthing.
Before the problems:
I changed the ignition coils, spark plugs and wires. One cylinder had a wire that was melted to the plug and the code for cylinder misfire still persists even though I changed it again.
I was told it might be the timing belt but I was wondering if anyone had an ideas on what else it might be. i am buying a code reader today and I will update as soon as I get more information.
ANY HELP IS GREATLY APPRECIATED
Things I tried:
