Tranny fluid leak and coolant in the engine?
Old Jun 14, 2010 | 07:42 PM
chevydrvr's Avatar
Default Tranny fluid leak and coolant in the engine?
I went to look at a 1994 camaro 3.4l v6. They said the engine was getting coolant into it. My mom's boyfriend (years of experience on auto mechanics) said that may be caused by a head gasket.
They also said the transmission leaks fluid, but it doesn't gush out fluid when it runs or anything.
SO my questions are
1. What does it take to fix the coolant problem?
2. Could the leaking fluid be caused by a bad seal? Please let me know as soon as possible. I want to know if it's worth buying.How much would this cost to fix. Could I do it myself. I probably could, but would it be easy?
Old Jun 14, 2010 | 07:58 PM
osduck5's Avatar
It sounds like either an intake leak or head gasket leak for the coolant in the engine. Have the cooling system pressure test to determine if indeed it is a head gasket. The tranny could be the front seal or it could be the pan gasket itself.
Do you have patience, tools, jacks and ramps, metric and standard hand tools? If so, you more than likely can replace the headgaskets yourself. You will need to find a machine shop to at least pressure test and surface the heads before reinstalling. It is not hard to replace the head gaskets and intake gaskets, just time consuming and takes alot of patients. As far as the tranny, I have never replaced the front seal, but the pan gasket should not be a problem to repair yourself.
If you are planning on having a shop do the repairs for the head gaskets, my guess is that it would not be a good deal for you to buy the car. You could be looking at $800 repair and up, usually UP!
Old Jun 14, 2010 | 08:28 PM
You have coolant in the oil? If you have been driving it with coolant in the oil the engine is most likely shot.
Your mom's boyfriend should have told you that antifreeze has a chemical reaction with the babit on the bearings. I warn you of this because the head gasket is not a easy job. I would hate to see you do that much work just to have a bearing spin a week later.
Old Jun 14, 2010 | 09:08 PM
chevydrvr's Avatar
Well, i'm probably better of finding another car. Thanks guys. It's a good car except for those things. They are just too much for me. I'll find another one.
Old Jun 14, 2010 | 09:44 PM
osduck5's Avatar
Hang in there, you will find one or check around some of the local salvage yards to see if they have a replacement motor for a decent price. You could probably get the engine replaced cheaper than getting a head gasket job done.
97z28kidd
Mar 1, 2012 03:39 AM
LiMariee
Feb 19, 2010 11:14 PM
bobarian91
Nov 4, 2008 10:59 PM
jkkrs310
Jan 11, 2008 10:49 PM
2002 Camaro Novice
Aug 19, 2006 11:00 PM
