1997 z28 trans fluid leak
Old Mar 1, 2012 | 12:42 AM
97z28kidd's Avatar
Angry 1997 z28 trans fluid leak
I just purchased a 1997 z28 camaro put less than a 100 miles on it and it started pouring fluid from the front seal area and I recently replaced the front and rear transmission seals at first it was ok til I got on the freeway when I exited I seen smoke and smelled burning trans fluid and looked under the car and it was pouring out again I was wondering if the transmission is bad or was the seal at fault any input would be appreciated
Old Mar 1, 2012 | 03:39 AM
could be to much slop in the front shaft. could be a bad install. where was the fluid coming from, the transmission inspection plate?
LiMariee
Feb 19, 2010 11:14 PM
1996fbodyz28
May 14, 2009 11:15 PM
bobarian91
Nov 4, 2008 10:59 PM
jkkrs310
Jan 11, 2008 10:49 PM
2002 Camaro Novice
Aug 19, 2006 11:00 PM
