suspension
Old Apr 23, 2010 | 12:29 AM
MusicMan's Avatar
The Jazz Man
For a good handling setup, decent price:
SLP Bilstein shocks or KYB AGX shocks all around (bilstein is more preferred than the agx's)
Strano lowering springs (proven good on corners, linear spring rate) Another good choice is the new BMR lowering springs.
WS6 or SS front sway bar (32mm) w/ poly bushings and links
19mm rear bar (z28 or TA I think, been a while) Any bigger and the back end wants to get loose. Poly bushings and links.
On-Car adjustable panhard rod (to center the rear after lowering) poly bushings, stay away from rod ends.
Moog solid rubber bushings for your stock lower control arms, these are great for handling. Stay away from poly bushings in the LCA, they bind, and act as a large sway bar. Rear end gets loose fast, think about how the suspension articulates.
Don't waste money on a shock tower brace, they're more for looks. Subframe connectors aren't really a big deal unless you're making some serious power and heaving that thing on the corners, I wouldn't worry too much about them.
Old Apr 23, 2010 | 04:01 AM
luciora's Avatar
Great Advice!
Old Apr 23, 2010 | 05:41 AM
I knew it was 19 MM rear sway bar but for some reason I typed 29. Most of the people I have seen that use there cars as daily drives that have gone with 1.75" drop have backed up to the 1" drop.
Old Apr 23, 2010 | 03:47 PM
traumadog's Avatar
...Subframe connectors aren't really a big deal unless you're making some serious power and heaving that thing on the corners, I wouldn't worry too much about them.
The reason why I recommended them was that he's got a convertible, like I do. And I can tell the difference with/without the SFC's on the lumpy roads I have in NY. (Heck, with the top down and the car on a lift, I can SEE the chassis flex).
Otherwise, if he had a V6 coupe, I wouldn't have suggested them. And if he really does go with 18's, then the rattling on uneven roads will get much worse.
And +1 to the adjustable Panhard rod to go with any lowering springs. You'll definitely need it for a proper alignment.
Old Apr 23, 2010 | 08:59 PM
libertyforall1776's Avatar
The first thing you should do is add a strut tower brace, you will immediately notice the difference and it is an easy install.
Old Apr 23, 2010 | 09:00 PM
*I* want both ;-)
do you want better handling or better ride quality?
(P.S. I'm kinda starting to look into this stuff too, so I hope you don't mind if I piggy-back this thread a little bit lol)
Old Apr 23, 2010 | 09:05 PM
That axle impact sounds like you need new jounce bumpers... The foam-rubber-like bumpers in the rear to cushion the axle.
id like to drop like 1.75.2 inch's but what i have is original and the sound of my axle hitting my frame or what ever is driving me nuts a stiff ride wont be too bad and ya i dont mind you piggybacking on this thread hopefully it will get me more info on this
Old Apr 23, 2010 | 09:08 PM
You may also need new shocks/struts if your jounce bumpers are fine...
im not getting any squeaks form the top or anything but it is a 95 and the entire car is original even the brakes and the sound im getting is the suspension bottoming out when i hit rr tracks or potholes and sht like that i also have 18 inch rims for it and with the tires there smaller than the stocks so thats why i want the drop to fill the wheel wells a little better
Old Apr 23, 2010 | 09:14 PM
traumadog's Avatar
Somehow, I doubt that your car is hitting the jounce bumpers with just crossing over RR tracks - at least with intact springs. You might want to peek under the car and have someone bounce the car up and down to see if any bolts are moving - specifically any that locate the shocks or the Panhard rod. Like I said, I heard a noise that sounds similar - just from a loose Panhard rod bolt.
Old Apr 23, 2010 | 09:29 PM
  #20
You provided a lot of good ideas and thoughts, but totally wrong on the strut tower brace. On both my RS & SS I noticed an immediate dramatic improvement by adding one -- in cornering, U-turns and lane changes. It may be less noticeable if you already have other suspension improvements, however.
As for SFRs, I plan to add them to both my RS & SS -- tying together the subframe is structurally very elemental and I will report back what I notice after adding them...
Boog1313
May 6, 2013 11:39 PM
97Beast
Aug 6, 2011 07:20 PM
MusicMan
Feb 21, 2009 11:01 AM
99camaro00
Jul 14, 2008 07:48 PM
nuttyprofessor
Oct 1, 2007 05:41 PM
