Starter problems?
Old Jul 15, 2010 | 08:22 PM
Kendagenius's Avatar
Default Starter problems?
Starter went out on me yesterday. Replaced starter today.... When it was time to connect battery back the car is trying to start without the key in the ignition switch!!!!! Had the starter took out and put in again with the same results... what could be the problem??????
Old Jul 15, 2010 | 09:49 PM
That means that the control wire to the solenoid has constant power on it, should only have power when the key is turned to the start position. Could be due to a wiring problem, faulty ignition lock, faulty starter solenoid (stuck on), wiring error, start relay contacts welded due to overload.. Use a voltmeter or test lamp to see if there is constant power going to the control lead.
Old Jul 15, 2010 | 10:35 PM
osduck5's Avatar
I had the same problem when we put the new engine in my daughters car. The main cable coming from the battery to the starter had a small 90 degree tab on it that was suppose to keep the cable from trying to twist as one tightens the nut and we did not have it aligned properly. Once the cable was tightened down, the lip was touching ground causing the engine to try and start even with the key off.
rktect69
May 26, 2010 08:31 PM
a-dusty-camaro
82-92 V8 Tech
May 12, 2009 10:05 PM
a-dusty-camaro
Mar 15, 2009 01:55 AM
1994z28
Nov 25, 2007 03:49 PM
Jaguar543
Oct 9, 2005 07:24 PM
