starter problems
Old Mar 12, 2009 | 10:15 PM
a-dusty-camaro's Avatar
Default starter problems
my 87 camaro has had troubles starting in the past month. ive only had it for like 2 months.
But recently its been were my starter cranks it doesnt turn over. i crank it few more times and it turns over and i have to rev it to get it running good.
im no mechanic. so i dont know what this is. It makes a crankin noise.
should i just buy a new starter or what else should i check
Old Mar 20, 2009 | 10:37 PM
84 Z28 Bowtie's Avatar
If its cranking, it isn't the starter or alternator.
Sounds like a fuel or spark issue.
Step one is to clean the battery terminals and then make sure they're tight.
Dump some fuel system cleaner in the tank (I usually add two bottles for something like this)
The next logical place to start would be a basic tune-up (depending on whether any / all of these have been changed lately) change:
Fuel filter
Spark plugs
Plug Wires (if you're a novice mechanic and do this yourself, ensure you only replace one wire at a time.)
Distributor Cap (ditto the above if you change the cap. transfer one wire at a time to avoid confusion, note where the #1 wire is and work clockwise from there)
Distibutor
Rotor
Hope that helps a bit.
Good Luck, let us know how it goes.
Old Mar 21, 2009 | 01:03 AM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
is it fuel injected or carbed? if it is f.i. it could be a weak fuel pump, if carbed it could be your choke or just the carb itself. do you pump it before you start it? or just try turning it over?
Old Mar 31, 2009 | 10:35 PM
now im having different problems.
It starts but wants to die and it boggs down and backfires a little bit when i rev it. but it dies if you dont rev it.
ive replaced Rotor. Distributor, Distributor cap. but im stumped to why its running like this...
Old May 12, 2009 | 10:05 PM
chadriley5's Avatar
Default starting problems
if your car is fuel injected,you may want to change the cooling temp sensor a faulty one will make it difficult to start
86cam350
Apr 16, 2011 01:15 PM
rktect69
May 26, 2010 08:31 PM
a-dusty-camaro
Mar 15, 2009 01:55 AM
1994z28
Nov 25, 2007 03:49 PM
Jaguar543
Oct 9, 2005 07:24 PM
