Starter problems
Old May 21, 2010 | 09:10 PM
rktect69's Avatar
Default Starter problems
I'm new to this forum so hopefully somebody can help. Had my 69 Camaro in storage for two years. Took it out last week, changed the fluids and she started right up. Since then it won't start. The original starter solenoid was clicking continuously when trying to start so I replaced it. Now the new solenoid only clicks once each time you try to start the car. The battery seems to be ok but I'm going to get it tested. Any other recommendations?
Old May 21, 2010 | 10:43 PM
Test the battery, check the battery cables at BOTH ends! If it doesn't gorund well to the block it can act like bad battery or cables.
Old May 22, 2010 | 12:18 AM
Did you test the starter while it was off the engine? You can use jumper cables. Do you have your battery ground cable going directly to the engine? If the battery, connections, and starter check out ok, it could be too tight of a mesh between the bendix gear and flywheel causing a wedgy.
Old May 22, 2010 | 03:50 PM
rktect69's Avatar
Default Thanks for the help
Got the battery tested and it was bad. Replaced that but still wouldn't start. Tested the starter and that was bad too. Got that replaced and now she's running fine.
Old May 22, 2010 | 04:28 PM
Great! Glad you got it working!
Old May 26, 2010 | 08:31 PM
BigJCamaro67's Avatar
Sounds like everything was bad. I had a 75 jeep and it would eat through solenoids all the time. That's usually what the rapid clicking is. Is the solenoid trying to latch then comes open and repeats over and over again. Good to hear that it's running again.
86cam350
Apr 16, 2011 01:15 PM
a-dusty-camaro
82-92 V8 Tech
May 12, 2009 10:05 PM
a-dusty-camaro
Mar 15, 2009 01:55 AM
1994z28
Nov 25, 2007 03:49 PM
Jaguar543
Oct 9, 2005 07:24 PM
