starter problems.
Old Mar 12, 2009 | 11:22 PM
a-dusty-camaro's Avatar
Default starter problems.
my 87 camaro iroc z 305 tpi has had troubles starting in the past month. ive only had it for like 2 months.
But recently its been were my starter cranks it doesnt turn over. i crank it few more times and it turns over and i have to rev it to get it running good.
im no mechanic. so i dont know what this is. It makes a crankin noise.
should i just buy a new starter or what else should i check
Old Mar 12, 2009 | 11:24 PM
Saint_Ali's Avatar
well it cant be the starter if it is cranking, sounds like you either arent getting spark or fuel
Old Mar 12, 2009 | 11:43 PM
so im prolly gonna need to replace the spark plugs. is this hard to do cause it looks like the spark plugs are hard to reach on the 305 is it easy if i put it on a lift and do it from underneath or easier from under the hood?
Old Mar 12, 2009 | 11:48 PM
Saint_Ali's Avatar
some you can get from the bottom, some you can get from the top.just because you may not be getting spark, doesnt mean its the spark plugs.it could be your spark plug wires or even distributor.But when you pull the spark plugs out,take a look at them, they may or may not be bad.
Old Mar 12, 2009 | 11:51 PM
**** sounds hard.
Old Mar 14, 2009 | 11:18 PM
91_Camaro_RS's Avatar
Maybe video tape this problem and put it on youtube or something, then post the link.
Old Mar 15, 2009 | 01:53 AM
c4maro's Avatar
If its cranking, and hitting the flywheel sometimes, it sounds like a bad solenoid, the solenoid is the thingy on the starter that moves the pinion forward to connect with the flywheel, therefore if this isent engaging, its not moving your engine components and starting the car. get a new starter.. i recommend BOSCH, for a third gen.
Old Mar 15, 2009 | 01:55 AM
c4maro's Avatar
And i have a 305. and the plugs are EAAAASY to get out. unless u got headers on there.
But i think u have a bad solenoid cuz u said the starter cranks, but it dosent turn the engine over.
86cam350
Apr 16, 2011 01:15 PM
rktect69
May 26, 2010 08:31 PM
a-dusty-camaro
82-92 V8 Tech
May 12, 2009 10:05 PM
1994z28
Nov 25, 2007 03:49 PM
Jaguar543
Oct 9, 2005 07:24 PM
