service engine soon light came on!!
once u get to 94s odb 1.5 u need a scanner. actually in the camaro the 93 is the only one that flashes the codes. well threre may be a few 94s that do also. i believe the problem that caused the ses light to come on will need to happen 3 times before it will store a code. also on the 98 u should be able to scann the car while its running also. helps alot.
Yeah, your 100% right on with the OBD 1.5 in 94. Some early '94s flash the codes, but mine does not. As for your situation, just figure out the code number and post it here and you'll get some help.
my SES light comes on often, and i've had it scanned several times by auto zone and they haven't found anything wrong with the engine. Granted it was rebuild so it may just need to be reset.
I've also heard that while traveling in over-drive, when you let off the gas and reduce your speed below 65, the SES light will also pop on.
The SES light should not go on, unless something is wrong.
mine did that to right when i bought it, i drove it like 200 miles right after, and nothing went wrong.. that was about a month ago, and its still running just fine, i wish i lived with in an hour of the closest napa, or advanced. lol.
Interesting that you mentioned that. My daily driver, a 2002 Chrysler 300M has that feature built in. All one needs to do, is to turn the ignition key ON, OFF, ON, OFF, ON and the trouble code is displayed in place of the mileage on the odometer.
