Replacing ' Heater hose bypass fittings" on 98 Camaro v6
Old Jul 19, 2011 | 08:27 PM
Ana A.'s Avatar
Default Replacing ' Heater hose bypass fittings" on 98 Camaro v6
Two times today, the Heater hose bypass fitting, that is positioned between belt tensioner and intake manifold, on my 98 Camaro, tried to be replaced. The first one was put in to far, by mistake. That one came back out in pieces. The second one, ( with lubricant this time), just broke. Can someone please explain to me what the correct way of replacing that part is. Thank you. Ana A.
Old Jul 19, 2011 | 08:35 PM
dang this one has been coming up alot lately. i have moved your thread to the 4th gen v6 section where you should get some help. welcome to the forum and read the rules next time you cant get to sleep. enjoy.
Old Jul 21, 2011 | 06:27 PM
REN's Avatar
REN
I will be doing mine next week when my parts come in. Had to scrape all the old debris prerry good.
I plan to use a little RTV sealant around the tube ends to help hold it in place. If all works well I will post again.
Old Jul 22, 2011 | 08:38 PM
hevymetalg's Avatar
I would not use rtv, it might seal something you don't want it to... You have to clean the bore out very very very good! That's the secret.
Old Jul 22, 2011 | 09:52 PM
grease or rvt, both have been recomended on here to help seal the elbow.
Old Jul 22, 2011 | 11:11 PM
REN's Avatar
REN
I have a non hardening RTV sealant that should work, I hope to never have to change it again. The throttle body side is hard to see if it is all cleaned out though. New water pump arrived today plan to put it in and hope it all seals.
Old Jul 23, 2011 | 07:16 AM
hevymetalg's Avatar
Grease, or oil is fine,but make sure their is nothing in the bore. Finger it!
Old Jul 23, 2011 | 11:40 AM
Ana A.'s Avatar
Default Heater Hose bypass fitting for my 98 Camaro v6
Thanks to all that left comments for me. I will pass them on to my son, next week, when he has a day off to work on my car. Thanks again to all. Ana A.
vanquishfist
Mar 20, 2013 12:20 AM
teamfalcon
Jul 28, 2010 11:14 AM
eMachine
Jul 18, 2009 02:56 PM
kyleb
Feb 6, 2008 02:07 PM
gearyr
May 24, 2007 08:47 AM
