my camaro dieing
Old Feb 14, 2012 | 12:42 PM
dogdog130's Avatar
Default my camaro dieing
well i believe my camaro is dieing she has 272K miles on her 3.4 lt well she starting burn oil so bad it smoking any ideas where it it would be leaking
Old Feb 14, 2012 | 01:08 PM
Is the smoke coming from the exhaust or from under the hood?
Old Feb 14, 2012 | 01:17 PM
dogdog130's Avatar
the hood
Old Feb 14, 2012 | 01:21 PM
BasicConcepts's Avatar
Technical User
check around the valve covers it leaks from there and then burns on the exhaust... could be a very easy cheap fix... also if it is the valve cover gaskets you may want to replace the covers. they used a cork gasket and its a huge PITA to get the gasket off the cover
Old Feb 15, 2012 | 11:15 AM
lemontime's Avatar
Huge PITA is an understatement, I had to redo those gaskets this past weekend on my 3.4 and I sincerely hope I never have to do that again.
Old Feb 15, 2012 | 11:24 AM
Technical User
i had other words in mind but the forum edits them...it would have been more like "**** ***** **** *** **** ***** hard"
Old Feb 15, 2012 | 06:05 PM
Well it could be the rear main leaking on the Y-pipe. I guess that would not fall under the "up side"
jlala
Oct 21, 2009 06:36 PM
Camaro_Boi69
Nov 2, 2008 01:11 AM
emt59602
Oct 4, 2008 12:02 AM
snapper08
82-92 V8 Tech
Dec 9, 2007 08:57 PM
z28steve
Sep 17, 2006 02:35 PM
