My 95 Camaro 3.4 Build Thread!
Old Feb 6, 2011 | 01:06 PM
  #41
Massey's Avatar
Yea I'm that good!
Old Feb 6, 2011 | 01:09 PM
  #42
Chaotic94's Avatar
September 2011 ROTM
inorite
Old Feb 6, 2011 | 03:14 PM
  #43
mrfreez's Avatar
Originally Posted by HARDABS05
purchasing any new parts this winter?
Posi rear-end with 3.42 gears, one-piece driveshaft, new tires, brake pads, rotors, front sway bar. Then I'm re-doing the lower intake gasket, valve cover gaskets, upper intake gaskets, new fuel injectors, and extending the CAI downward, bypassing the coolant lines going through the throttle body, new IAC motor.
That ought to cover it for now.
Old Feb 20, 2011 | 03:01 PM
  #44
mrfreez's Avatar
Well, I got my posi rear-end today! 3.42 gears!
Can't wait to get it all together and put it in the Camaro! I'll be cleaning up the housing nice too!
Old Feb 20, 2011 | 03:50 PM
  #45
Chaotic94's Avatar
September 2011 ROTM
Looks sketchy... Good luck. Posi will suck if it's your DD. You'll squeak tires at EVERY corner lol
Old Feb 20, 2011 | 05:06 PM
  #46
mrfreez's Avatar
The rear end had 97000km (60625mi) on it. The gears are perfect. I'm putting it together and putting new bearings in.
Why will posi suck? Z28's have them!
Old Feb 20, 2011 | 09:48 PM
  #47
Chaotic94's Avatar
September 2011 ROTM
NO!!! Z28's have limited slip so they don't squall tires going around corners.
Old Feb 20, 2011 | 10:52 PM
  #48
if he has a locker or welded spider gears in the rearend then it will jump or chirp on the corners. positrac is limited slip.
Old Feb 20, 2011 | 11:01 PM
  #49
Chaotic94's Avatar
September 2011 ROTM
^Not what I've been told in the past...
Old Feb 20, 2011 | 11:15 PM
  #50
3800camaro's Avatar
Chaotic is right. Posi and limited are the same but different. Posi is fully locked and limited slip is what it says.
