Jumpy.
Old Sep 6, 2007 | 09:15 PM
The Banks's Avatar
Default Jumpy.
I'm not sure if this is normal, but if I change gears on my automatic from a stand or roll, and press the gas preatty quickly after I have done so, that the car will jump.
Old Sep 6, 2007 | 09:34 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: Jumpy.
sounds normal. its the power hitting the wheels through the wheels
similar to an upshift in a manual with the pedal floored or a downshift into a gear that is still too high. the motor is at top hp, and this goes to the wheels until the clutch/torque converter grabs enough to pull the motor back down. you get kind of a jump, then regular acceleration for that gear
Old Sep 7, 2007 | 07:00 PM
Chappie99's Avatar
Default RE: Jumpy.
great way to blow up your rearend.
Old Sep 8, 2007 | 06:52 PM
Default RE: Jumpy.
Not only the rear end, but the transmission will wind up breaking also. You have to wait for the gears, clutches, bands, etc. to engage before applying power.
Old Sep 8, 2007 | 07:39 PM
Chappie99's Avatar
Default RE: Jumpy.
what we are trying to say, bad idea.......
ossur4@comcast.net
82-92 V8 Tech
Jun 20, 2010 12:24 AM
Chevykicksbut
Mar 24, 2010 11:37 AM
Bubonic
Feb 20, 2008 06:09 PM
305stang
Jun 1, 2006 04:16 AM
Damien8086
May 18, 2006 12:18 PM
