jumpy tac and guages on a 91 z-28
Old Jun 19, 2010 | 12:35 PM
ossur4@comcast.net's Avatar
Question jumpy tac and guages on a 91 z-28
I am having a problem with the electrical on my camaro. The car runs great however the tac will max out upon exceleration, all of the guages are jumpy constantly, head lights flicker, and I can hear a constant noice from the radio. I have had a mechanic check it out they did the following and found no reason why it was doing that -suggested that I replace the computer brain.
Battery check
alternator check
ground check
fuses
pulled brain and cleaned connections
Any ideas.
Tony
Old Jun 19, 2010 | 12:40 PM
gfrench's Avatar
Do you have a large stereo amp?
Old Jun 19, 2010 | 02:53 PM
62rampsidekid's Avatar
Would interested to hear what you find. My 88 v6 has simmilar quirks, when I use the right turn signal all the guages bounce with the blinker but stop after the signal is off, when the left signal is used the tach bounces slightly with the signal but nowhere near as much as the right. When the head lights are on the tach pegs out, the voltmeter reads near 8 volts even thought the battery is new, the charging system has been check and I have cleaned all the ground connections I have found so far. This car sat for the last 5 years and I have slowly been going through it getting it going so maybe I will find something sooon.
Good luck with your problem.
Old Jun 19, 2010 | 08:06 PM
No large amp system. In fact I disconnected the stereo thinking that may be it.
Old Jun 20, 2010 | 12:24 AM
Battery check
alternator check
ground check
fuses
Any ideas.
Tony
Have you checked all your ground wire connections; from the battery to the engine, engine to frame, and any others you can find.
Did the mechanic check the alternator by doing a load test? Another possibility is the voltage regulator could be bad (built into the alternator).
And be careful when doing the brain and connections thing, that ended badly once before...
Chevykicksbut
Mar 24, 2010 11:37 AM
Chevykicksbut
Mar 22, 2010 01:41 PM
Orion
Jul 31, 2009 12:26 PM
Bubonic
Feb 20, 2008 06:09 PM
The Banks
Sep 8, 2007 07:39 PM
