Hesitation issues
Like i said it could be a number of things. But everything you have said sounds just like a failing coil. Plug wires first, if it get a little better you can get a spark tester to test to see which coil is failing. I would bet by the end of next year you will have replaced all the coils.
i am having a similar problem with my 99 v6 5 speed. sometimes when i accelerate it hesitates and the check engine soon light is on but i thought that it could be beace i have no cat. what could it be sence the light is on?
first thing is to pull the engine codes, it will give you a pretty good idea where to start. autozone does it for free if you have one nearby.
