hesitation
Old Nov 24, 2006 | 09:49 AM
got3ofem's Avatar
Default hesitation
ok, I just put in a brand new zz4 350/355 in my 70 rs, and replaced my old carb w/a edelbrock 650 elect. choke thunder avs. it hesitates/cuts out for a second when I hit it down, but otherwise runs perfect. I have put in a new holley 110gph mechanical fuel pump, with dual feed lines, same problem. checked the fuel filter, was dirty, cleaned it, same problem. do I need to mess with the jets or rods to stop the problem? I just had the timing checked at the dealership, it was slightly retarded, but problem still exists. Thanks.
Old Nov 24, 2006 | 11:42 AM
v8chvyguy's Avatar
Default RE: hesitation
It could be a fuel mixture problem. Try swapping a known good Q jet on there and i bet it cures it. My brother and I had the same problem with both an Edelbrock and a Holley ended up rebuilt Qjets back on and have'nt touched them since. A 550 to 650 cfm Qjet will support 355 HP.
Old Nov 24, 2006 | 11:49 AM
shnormo's Avatar
Have any other mods been made? Sometimes the weights in the distributor are too stiff and won't allow it to advance fast enough.
Old Nov 24, 2006 | 12:33 PM
got3ofem's Avatar
thanks for the advice.
no other mods have been made yet. the engine comes w/an hei distrib from gm performance parts, and a gm alum. intake. i havent adjusted the accelator pump on the carb yet, edelbrock says that might fix it? may have to locate a qjet somewhere, dont have one, but would like to try not to change out the carb, it is brand new w/endurashine. ($430 bucks) and have spent gobs of money already..........
Old Nov 24, 2006 | 01:58 PM
Check the setting on the accelerator pump, try a bigger or smaller stroke & see which way the hesitation goes.
Old Nov 24, 2006 | 02:09 PM
got3ofem's Avatar
thanks, I will do that.
Old Nov 26, 2006 | 10:17 PM
69camaro1's Avatar
I've had that problem with a holley carb and backed out the accelerator pump almost all the way and it helped some but I think it still could be the timing. You might want to check both.
Old Nov 27, 2006 | 09:22 PM
firebird69racer's Avatar
Read the book that came with the Carb. It tells you how to adjust it. All carbs need to be tuned to each motor it goes on. The Edelbrock Carb is very easy to tune, most of the time its just a rod or spring change, Get a Calibration kit it will come with different power valve springs, rods, and jets
650 is kinda small for your set up, it will work ok but you will get more power from a 750
Where are you located
Old Nov 28, 2006 | 02:59 AM
81CanuckZ's Avatar
ORIGINAL: firebird69racer
Not necessarily...i think a 650 will be plenty for 355HP. Much better throttle response too.
Old Nov 29, 2006 | 08:43 PM
ORIGINAL: 81CanuckZ
[/quote]
It still needs to be adjusted to the motor, yes it will be close, but needs fine tuning
cadmanof50s
Aug 1, 2011 10:42 PM
eighty-eight-iroc
Jun 15, 2010 08:01 PM
ryan88z
Mar 26, 2008 10:51 PM
amnesia206
67-69 V8 Tech
Jan 25, 2008 05:06 PM
renee
Aug 12, 2005 11:13 PM
