5.7 tpi with hesitation... help
Old Jun 7, 2010 | 10:50 PM
eighty-eight-iroc's Avatar
Exclamation 5.7 tpi with hesitation... help
i have an 88 iroc-z with the 5.7 litre tune port injection. i just recently obtained it in a trade. it has sat for the past year. motor is super clean. when i start it up sometimes it idles at 500 rpms or lower. ill drive it and it runs great but if i am sitting at a stop and try to put the gas petal to the floor it falls on its face for a second then takes off. any ideas?? the check engine light comes and goes. some one said maybe a leaky injector???
Old Jun 8, 2010 | 07:49 AM
jasunf's Avatar
I had a similar issue when I mashed the pedal it almost stalled out then rev'd right up. Mine issue was fuel filter. After I changed that out it started to react much better.
Old Jun 8, 2010 | 08:22 PM
microkid's Avatar
March 2011 ROTM
Technical User
do the basic things first. first, put good fuel in it. then check out the spark plugs and wires, and replace if they look old. check the timing with a timing light and set it if needed. also check the air filter and replace if needed, and get a can of mass air flow sensor cleaner and clean the maf
Old Jun 15, 2010 | 08:01 PM
jcase350's Avatar
I am having the same problem. Did you find out the problem?
cadmanof50s
Aug 1, 2011 10:42 PM
ryan88z
Mar 15, 2009 08:29 PM
ryan88z
Mar 26, 2008 10:51 PM
amnesia206
67-69 V8 Tech
Jan 25, 2008 05:06 PM
renee
Aug 12, 2005 11:13 PM
