LT1/LT4 Tech 1993-1997
Bad Hesitation
Old Mar 8, 2009 | 03:17 PM
ryan88z's Avatar
Default Bad Hesitation
Ive got a 95z with the six speed. If i just have the car idleing and i snap the throttle to the floor the car will die. if i do a gradual to the floor no problem. while driving if at a low rpm range in the gears. i'll get on it hard it will hesitate bad too. any suggestions
ryan
Old Mar 8, 2009 | 05:13 PM
95slvrZ28's Avatar
Have you checked for vacuum leaks? Sounds like this could be your problem. Any other symptoms? SES light on? etc.
Old Mar 8, 2009 | 05:18 PM
If all the above mentioned looks OK, check out the TPS (Throttle Position Sensor). Make sure all wiring is good, and check the resistance as you work the throttle. Use an analog meter and watch the needle movement.
Old Mar 8, 2009 | 06:27 PM
ryan88z's Avatar
i did check for vacuum leaks yesterday and everything seemed ok. i just went to the gas station and when i was coming back there is a stop sighn at a hill it allmost stalled like 5 times b4 i could get it to go because i had to give it the extra gas for the hill. then about a mile down the road i got on it doing like 30mph and it almost stalled then backfired like a firecracker and saw a puff of smoke out the back.. will check the tps . there is no ses lights on.
Old Mar 8, 2009 | 08:11 PM
robmnrd's Avatar
Sounds like a fuel problem. Same thing happened to me a couple months ago, it turned out to be my fuel pump.
That's not necessarily your problem, but something fuel related is what I'd bet my money on right now.
Old Mar 8, 2009 | 08:21 PM
ryan88z's Avatar
it could be robmnrd. It allways starts hard, have to try like 3 times b4 it will start, but its been like that since i got it 2 years ago
Old Mar 8, 2009 | 08:27 PM
robmnrd's Avatar
I'd definitely get it checked out then.
But if it's been having starting issues for that long, and this new issue is just now starting, then chances are those two things are unrelated. Or at most one caused the other.
How many miles are on it right now?
Old Mar 8, 2009 | 08:33 PM
ryan88z's Avatar
well 140,000 on the car and about 80,000 on the motor
Old Mar 8, 2009 | 09:09 PM
robmnrd's Avatar
I'm at 150000, so if that's about what it takes to kill a fuel pump, it could be the same for you. :P
Old Mar 15, 2009 | 08:29 PM
ryan88z's Avatar
Well still looking for the problem. Put a new tps in. did plugs and wires cause it was time anyway. the only thing i did notice while doing wires is the vaccum pump. it has a plastic case around it and it has a couple of holes like where somthing hit it. could this be the cause of hesitation. it has gotten worse over the last week it really bucks when i get on it. Or is this one of those opti realated problems?
cadmanof50s
Aug 1, 2011 10:42 PM
eighty-eight-iroc
Jun 15, 2010 08:01 PM
ryan88z
Mar 26, 2008 10:51 PM
amnesia206
67-69 V8 Tech
Jan 25, 2008 05:06 PM
renee
Aug 12, 2005 11:13 PM
