fuel pump works.....guage doesnt
Old May 27, 2007 | 09:15 PM
worknon10s's Avatar
Default fuel pump works.....guage doesnt
98 v6 camaro
guage reads dead emptybut car runs perfect. do i need a new pump or is there somethig i can adjust or check to fix this?
how much is a new pump?
Old May 27, 2007 | 11:14 PM
usarmyrangrs's Avatar
Default RE: fuel pump works.....guage doesnt
The sending unit is more than likely defective. I'm not sure on the specifics, and how it's actually fitted into the tank, whether it's part of the pump assembly or not. I'm sure someone else on the boards can give you a more specific answer, but in a broad sense, no, you should not have to worry with a new fuel pump.
Old Aug 25, 2007 | 01:36 AM
Cosentino's Avatar
Yeah, it's all one unit, aka fuel pump module. Generally, your best bet is to replace the unit as a whole. It's cheaper than "piecing" it out (assuming you can fin done readily available) and there's no way of knowing that say two days after replacing the sending unit the pump won't go out and you'll have to drop the tank again. Napa currently offers Delphi exact OEM part replacements for a pretty good price. On most vehicles they're cheaper than the Napa Brand Fuel Pumps.
tyler_caz18
Feb 1, 2014 09:36 AM
osduck5
Aug 6, 2011 11:21 PM
camarofreak1990
Jul 5, 2008 10:27 PM
Camaro 2.8
82-92 V6 Tech
Aug 22, 2007 02:23 AM
z28pete
Jun 9, 2007 06:58 PM
