Engine hesitation/cuts out...
Old May 11, 2006 | 11:02 PM
Arock24's Avatar
Default Engine hesitation/cuts out...
I hooked up my '97 Camaro to a diagnostic (engine light came on) and it read cyl 4 misfire. The car doesn't do it all the time, just every now and then when I go to accelerate, usually at speeds of 50mph+ the engine cuts out every once in a while showing some real power loss. My guess was a bad plug, wire, or dirty fuel injector...I replaced the plug and checked the wire, still the same results, would a dirty injector explain my problem? Also, my engine light turned off as well, don't know what that means, but the problem's still there, any input would be helpful, thanks.
Old May 11, 2006 | 11:16 PM
ChaoticBastard's Avatar
Default RE: Engine hesitation/cuts out...
I think your car has a coil pack instead of a distributor.Most likely the pack is on the way out
Old May 11, 2006 | 11:19 PM
Arock24's Avatar
It is a coil pack, but that was just replaced when I bought the car...any thoughts?
Old May 11, 2006 | 11:54 PM
SickSickSick's Avatar
There Is Only Three Causes For Misfire. Ignition, Fuel, And Compression. You've Already Ruled Out Ignition. Injectors Are Fairly Cheap And Easy To Change.( You Already Know What Cylinder ). That Would Rule Out The Injector. The Third And Most Costly Can Be Checked Out With A Compression Gauge. You Can Get One Fairly Cheap And They Are Simple To Use. Hopefully The Injector Is Bad. If It's A Compression Problem It's Either A Valve Or Compression Ring. Sick
Old May 12, 2006 | 12:02 AM
Arock24's Avatar
I have a compression gauge but did not consider it because of the fact that it is not a constant misfire, it's very irregular...my bet is the injector, and I added some cleaner to my tank of gas tonight, how long should I wait for results? The entire tank or should I notice something earlier?
Old May 12, 2006 | 02:03 AM
if it was a ring it would be smoking in some way.Most likely electrical.A faulty map sensor can do the same thing.Although it would make it load up with fuel.
Old May 12, 2006 | 09:23 PM
Since The Problem Is Only On One Cylinder It's Less Likely A Sensor Malfunction. I Don't Put Alot Of Trust In Fuel Treatment But, Give It A Day Or So. What You Can Do Is While The Engine Is Running Look For Gas Seepage On That Injector. That Is A Tell Tell Sign Of A Roasted Injector. Just Because A Car Has A Bad Compression Or Intermediate Ring That Doesn't Mean It Will Burn Oil. Each Piston Has Three Rings. Compression, Intermediate , And An Oil Ring. It Is Very Possible To Have A Broke Compression Or Intermediate Ring Without It Burning Oil. Don't Be Fooled. Sick
Old May 15, 2006 | 11:19 PM
Arock24's Avatar
Alright, I'm still baffled by the problem, but I've narrowed down when it occurs...I only feel the loss of power in the car when I'm doing about 50-60 mph, and I try to accelerate gently, without making it downshift, I feel the hesitation until I lay off the accelerator or I make it downshift, then the hesitation is cleared up. I'm thinking I simply have a bad injector, and if it's Cyl. 4, it won't be easy to get to...
Old May 16, 2006 | 02:43 AM
Have you changed your fuel filter latley?
JGuy07
Jan 25, 2012 06:57 PM
camaroguy'92
May 13, 2010 09:33 AM
facingxtinction
Jan 16, 2008 08:03 AM
wvblair
82-92 V8 Tech
Oct 11, 2007 01:40 AM
atlanta2008
67-69 V8 Tech
Aug 14, 2007 09:41 PM
