Engine Hesitation and exhaust
Old Jul 25, 2007 | 06:56 PM
atlanta2008's Avatar
Default Engine Hesitation and exhaust
Recently I tried to adjust my carb (LOL) and went for a drive. After I drove for a while the engine seemed to miss or hesitate as I drove doen the road. I have a BB with a Holley 4 barrel. I'm assuming that I may have fouled a plug.
Is there any way to get rid of the exhaust smell?[:-]
Old Jul 25, 2007 | 07:59 PM
Default RE: Engine Hesitation and exhaust
Yes, change the plug and adjust the carb properly. If you are fouling plugs, the mixture is too rich, or the engine is burning too much oil, or you are using the wrong plugs.
Old Jul 26, 2007 | 07:03 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
What else did you do besides adjust the carb?
Old Jul 26, 2007 | 07:11 AM
Thanks for the reply
All I did was adjust the idle and the air fuel mix.
(I have recently installed a new tranny th350)
I assume that I fouled a plug? I have been having trouble with a strong gas smell from the exhaust and was hoping to help the situation. It seems I have made it worse. I was thinking that I may need to purchase a new carb. Any suggestions.
Old Aug 14, 2007 | 09:41 PM
69camaro1's Avatar
You probibly fouled a plug from runningso rich. To check for a fouled plug pull each plug one at a time while the engine is running and if you pull a plug and it runs worse that means the plug is good. But if you pull a plug and it dosn't run any different than you have a fouled plug. Also remember when adjusting the mixture screws that turning them left is rich and right is lean. It should idle around 700-800 rpm.
JGuy07
Jan 25, 2012 06:57 PM
xcorat
Aug 27, 2009 10:25 AM
facingxtinction
Jan 16, 2008 08:03 AM
Arock24
May 16, 2006 02:43 AM
