Where's my fuel filter?
Old May 16, 2006 | 01:12 PM
94camaroLI's Avatar
Default Where's my fuel filter?
I just brought a 94 camaro..it has a slight hesitation when I am either at a stop sign or light...I'm thinking my fuel filter needs to be changed...also I've notice that when that happens my battery and oil gauges tend to flick up and down....Does anyone have any suggestions? I plan to tune up the car plus change the oil and tranny oil and filter.
Old May 16, 2006 | 02:22 PM
akohnz's Avatar
Default RE: Where's my fuel filter?
Your fuel filter should be located under the drivers side kinda towards the back. The hesitation might be caused by clogged fuel injectors, also check the distributor, if there is water in there it will cause a hesitation. Also you might try just getting a tune up, if you havent had the car very long might want to look into just regular maintenance. a hesitation could be caused by anything. Hope this helps.
akohnz
Old May 16, 2006 | 09:57 PM
94camaroLI's Avatar
I'm going to check out this weekend. Just got the car a few days ago..so I'm just going to be on the safe side have a full tune-up. I'll have my cuz check the distributor. There's a fuel injector cleaner that comes with the tune up also.....thanks man!
jon_uscg2001
Aug 25, 2011 12:23 AM
lynxsrevenge
82-92 V8 Tech
10
Jan 16, 2011 04:32 AM
TrammelZ28
Sep 17, 2007 06:44 PM
johnson3034
May 25, 2007 09:35 PM
jtvyper456
Dec 31, 2006 09:33 PM
