burning up in Florida
The system will vent when you change the hoses. After venting tape all openings shut so that no moisture gets into the sytem. Don't bother refilling with the old freon R12 stuff, as it costs a fortune. There are retrofit kits available that will allow you to refill with substitute refrigerant such as Freeze 12, whcih is a lot cheaper, mixes with the old R12, and does not melt the O rings like R134a.
