cylinder 1 misfire??? wierd one.
Old Sep 11, 2008 | 07:32 PM
  #21
sallo's Avatar
Default RE: cylinder 1 misfire??? wierd one.
i dont think its injectors i switched the cyl 1 injector with 3 and the misfire stayed in one
Old Sep 11, 2008 | 07:40 PM
  #22
02StanGT's Avatar
I would do like Pete said, and check compression on other cylinders. There might be a problem with just that #1 cylinder.
Old Sep 11, 2008 | 07:51 PM
  #23
tammy's Avatar
Banned
Good man, that means the problem is static, have you ran any propane around the intake manifold? Could have carbon on valves? What are the fuel trim readings left bank and right bank?
Weak valve spring? Cam lobe worn? WHATS THE HISTORY ON THE VEHICLE?
Old Sep 12, 2008 | 12:41 AM
  #24
sallo's Avatar
i dont know how to get the fuel trim... i dont know the history on the car i just bought it last month it had the misfire and the guys mechanic couldnt find the problem so he sold it to me for 1000. i know the car has been wrecked before because the airbags have been repacked and they didnt do 2 good of a job at that. its got 124k miles on it and thats pretty much all i know. when i got it i was really worried because it smoked realy bad under the hood, when i got it home i checked the oil and it was about an inch over the max full mark. so i drained all the oil and filled it to spec, and it hasnt smoked scince. but with the lack of oil pressure in the top end i dont know if it damaged it. the farthest ive gone is taking off the valve covers and visually inpected, while running, i didnt see anything out of the norm...
Old Sep 12, 2008 | 12:48 AM
  #25
sallo's Avatar
if it were cylinder problems wouldnt the misfire happen at idle and low rpm also?
Old Sep 12, 2008 | 01:00 PM
  #26
02StanGT's Avatar
Not necessarily. There may not be enough air and fuel in the cylinder to notice the problem at that time.
Old Sep 12, 2008 | 02:48 PM
  #27
tammy's Avatar
Banned
You will need an oscliscope next to see the firing line work.
Old Sep 12, 2008 | 10:45 PM
  #28
RobsWreck98's Avatar
I think i can help my 98 3800 series camaro was recently doing the same thing i changed out my whole ignition system except the coils and it still was happening I ended up buying the msd coil packs for the 3800 series and it cleared it right up. If you want the same packs i got they are on www.3800performance.com they are the msd blaster coil packs
209Chevy
Jul 1, 2012 04:31 PM
lwg001
Nov 16, 2010 12:10 PM
gregcamaro
Apr 21, 2008 10:38 AM
JKEpps
Jun 25, 2007 12:13 PM
powers28ss
Oct 3, 2006 12:13 PM
