cylinder 1 misfire??? wierd one.
alright this ones got me, ive got a cylinder one misfire on my 96 camaro rs. what ive done: new plug wires, new ngk plugs, switched coils to see if the one that #1 plug is on with one of the others that i know are good checked the wires and connection on the fuel injector. i really dont know what else it could be, is there a sensor that could cause just a #1 misfire. ive also been told it could be the cat gunked up but coud that cause just a cylinder #1 misfire and not a multiple misfire? any ideas???
RE: cylinder 1 misfire??? wierd one.
also when i rev the motor up to about 2500 rpm theres a tick(knock) coming from around the #1 cylinder side of the motor, and it gets worst at around 4000 rpm.
Fuel injector could be going bad. Check it
alright i checked the injector on cylinder 1 visually it looks good but to maked sure i swapped it with one of the other injectors and the missfire didnt follow the injector its still cylinder 1 misfire. also i drove it after i got it all back together and sitting there it runs good, but when it heats up i can feel the misfire, especially when i get on it (4000 rpm+)
cross wired?
nope i wish it were that simple but ive checked and rechecked. i printed off the diagram off of alldata. any other ideas???
You check the compression?
im going to tomorrow its rained no stop all day and i cant get out there to do it atm. but i really hope its not burnt, bent valves or rings. if it were an o2 sensor cat or egr it wouldnt be just #1 would it?
Don't think so. With those you usually get a code for running lean or running rich, and a random misfire. Not normally a specific cylinder.
yeah thats what im affraid of i guess it all comes down to the compression test tomorrow, ill let you guys know how it goes tomorrow
