96 Brake upgrade
Old Jun 27, 2009 | 07:58 PM
Default 96 Brake upgrade
I am getting a little ahead of myself since I don't even have my motor back in yet but. I found a 2000 V-6 that is being parted out. He is selling stuff dirt cheap. Anyone know what all parts I would need to upgrade my brakes? 2000 V-6 the same brakes as the V-8?
Any one know of a write up by someone who has done it? I may not get the rear brakes cause I want a posi with disks. Although I am temped cause I think I could get the rear from this guy for 50 bucks.
Old Jun 27, 2009 | 10:32 PM
383Z28's Avatar
not sure if v6 is the same as a v8 if it helps you at all i have a ls1 front brake upgrade on mine brakes are off a 01 v8 car it has dual piston aluminum calipers and 12in rotors to do the swap you need rotors calipers caliper bracket and i would take the monts to the caliper bracket not 100% sure about the monts same goes for the rear and you would need the e-brake cables as well
Old Jun 28, 2009 | 10:52 AM
evilkal's Avatar
The 98-02 Camaro's all had the same brakes
Old Jun 28, 2009 | 10:53 AM
19camaro85's Avatar
can someone help me with question on 85 camaro
Old Jun 28, 2009 | 12:34 PM
02StanGT's Avatar
Sure. Either PM someone, or you might try posting your question in the 3rd Gen section, where I'm sure you'd get alot more help.
Old Jul 3, 2009 | 07:35 PM
I am not seeing how these front rotors can fit. The spindle wraps around the rotor at the top with about .150 clearance. The rotor is 3/4" bigger. I will get some pics up.
Edit:
This picture show the priginal rotor still installed and the 12" rotor put on the lugs backwards.
Old Jul 3, 2009 | 10:10 PM
Crap I need the whole spindles! Its a fricken 1-1/2 hour drive back to where the car is.
http://cgi.ebay.com/ebaymotors/93-97...4506.m20.l1116
Dark Syde
Jan 20, 2011 10:43 PM
Z26
Mar 31, 2009 03:48 PM
spacemule
Feb 8, 2009 09:38 PM
xdreamweaverxad
Sep 9, 2008 08:49 PM
Slick6
Apr 27, 2007 07:56 PM
