Power brake booster upgrade?
Old Jan 16, 2011 | 08:14 AM
Dark Syde's Avatar
Default Power brake booster upgrade?
I am working on my front subframe resto and need to order a disk brake upgrade kit today. Is upgrading to "power brakes" as simple as ordering the kit that comes with a booster, and then finding a vacuum feed line to hook up to? My 67 currently does not have booster. It is a small block with standard valve covers, so clearance should not be a problem. Is the power booster kit worth the trouble or just stick with the original setup? It will be a weekend driver and not going to the track. I just want to enjoy driving it.
THX!!
Old Jan 16, 2011 | 12:06 PM
carguy68ssrs's Avatar
Do the power brakes, it is definetly worth it.
Old Jan 17, 2011 | 09:06 AM
hrracecar's Avatar
Default Disc Brake Kit
http://www.racingjunk.com/category/1...-Chevelle.html
As stated above, if this is a driver you will be glad you made the change to power discs. Check the link above to a complete changeover kit our shop sells for $535 shipped. Everything needed to convert to power disc. Good luck with your project.............Toni www.hrracecar.com
Old Jan 17, 2011 | 12:52 PM
brunk5's Avatar
I am reviewing my options on adding the vacuum assist and would like to know what parts have to be changed out. Such as the master cylinder. Do you have to get a specifically designed master cylinder to mate with the vacuum canister? For example, I read that you must use a deep well master cylinder if you don't have vacuum assist. Can you use the deep well with the vacuum assist? Will it fit under the hood?
Any help is appreciated,
Joseph
Old Jan 18, 2011 | 08:59 AM
hrracecar's Avatar
The biggest difference is that the piston diameter inside the master cylinder is different between the two. The manual mc must make more pressure without any assistance from the booster..Do you currently have manual disc brakes?..............Toni www.hrracecar.com
Old Jan 18, 2011 | 09:50 AM
Dark Syde's Avatar
Wow... I thought that I had done all my research and asked all the right questions. Always more too it than one might think!
Yes, I currently have manual drum brakes that appear never to have been touched. They are off the car now and I am working on rebuilding the front suspension. It looks like the conversion kits come with booster and piston, and matching master cylinder. What else do I need to consider?
THX
Old Jan 19, 2011 | 08:41 AM
hrracecar's Avatar
I think that should be most of it. The power booster push rod will attach to your brake pedal arm in the lower hole. If you look under your dash at your current push rod there will be a mounting hole about an inch lower. Sometimes they have a plug in them. With the booster you will not need as much leverage to push the brakes so you use the lower mounting hole. Hope this helps...........Toni www.hrracecar.com
Old Jan 19, 2011 | 07:31 PM
dynarider33's Avatar
Check out this site. http://www.getdiscbrakes.com/rightstuff/Default.aspx Complete upgrade kits with no guess work. I have installed 3 of them on Camaros and Chevelles.
Old Jan 19, 2011 | 11:24 PM
1969 SS's Avatar
I have a used booster in real good shape that I'd be willing to sell cheap. I bought it brand new for my 69. I had it on there for about 3 or 4 summers before I went to a mini booster
Old Jan 20, 2011 | 10:43 PM
Bandit63's Avatar
January 2011 ROTM
Go with the power disc brakes. Also I would replace all the brake lines............
exlimey
Feb 1, 2012 04:23 AM
sprtplt
Aug 8, 2011 06:33 AM
typeomang
Jun 14, 2011 02:00 AM
383Stro
Sep 29, 2010 12:08 AM
sbrewer71569
Mar 1, 2007 02:44 AM
