96 to 01 Engine swap
Old Mar 24, 2008 | 07:12 PM
raymose's Avatar
Default 96 to 01 Engine swap
I have a 1996 Camaro. Bought a 01 engine at a junkyard with 7k miles on it. Service book says only mod needed for the swap is the old intake manifold. Anybody do this yet? Anyone know where I can get a replacement intake manifold(1996). Searched the net but none look the same as my old one. I dont want to use the old one since the reason the engine blew was problems from an intake manifold coolant leak. thanks
Old Mar 24, 2008 | 07:23 PM
importmd's Avatar
Default RE: 96 to 01 Engine swap
your 01 motor is a ls1, and if you have a z28 you have a lt1. nothing interchanges between the two. what book are you reading? unless your manifold is cracked, it was just a gasket that caused the leak.
Old Mar 24, 2008 | 07:25 PM
raymose's Avatar
the o1 is a 3800 series II v6. same engine just different upper intake manifold for the electric throddle body
Old Mar 24, 2008 | 07:27 PM
importmd's Avatar
opps, my bad i thought this was in the v8 section. sorry
Old Mar 24, 2008 | 08:05 PM
02StanGT's Avatar
I'd keep checking eBay and www.tacreationsusa.com for manifolds. I have a spare one I'm porting/polishing. I got mine off eBay. That website I listed, has some decent prices, though right now they don't have any in stock. Was/is there a crack in the manifold, or was the gasket just leaking?
Old Mar 24, 2008 | 08:09 PM
raymose's Avatar
no idea if theres a crack or the if the gasket was leaking. i changed the gaskets and it seemed to do the trick but then the engine went afterwards. and with this new engine i got id rather not take a chance
Old Mar 24, 2008 | 08:16 PM
02StanGT's Avatar
Only other things I can think of to check is craigslist or local junkyard.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
